gm 10 bolt frount axel ???and 14 bolt rear
tennessee_4x4_man
i need a little info got a 3/4 frount axel gm corpration not dana 44 is it a 8.5 or 8.6 ring gear to use a 4.10 gear to a 5.13 do you haft to have a stage 4 carrier or can a ring gear spacer be used rear is a 14 ff where is best place to buy break brackets for the rear
Post a picture of it ...
It should be a 8.5"
If I read Your question correctly : if you currently have a carrier with a 4.10 you should be able regear to a 5.13 using the same carrier
I think the 8.6 is a 99+
