Gots me another 60
blacksheep10
XBJRA champ/ 555 and team Nasty codriver
Kansas, where we know how to wheel, nowhere to go
HP with 4.10's this time, woot!
getting another tomorrow for some work I did in the spring, and can pick another up tomorrow if I want to spend $700 on a dually. undecided on that yet, though.
No pics, I'm just celebrating. I've wanted an HP for so long, now i finally have one 2 years later.
you want that ford HP for $7 bills? I can go pick it up. I know you can sell your 60 for that. 300 flip kits are cheap. use your chebby knuckles and outers on it, no one is the wiser when they buy a chebby front with ford outers and these "cool" dual piston calipers. :spin: :D
seriously, I'll get it.
I now have 2 hp 4.10 60 fronts. Paul, your trade is looking more likely. hit me up. you can keep the chebby outers for better knuckles and cheaper brakes. I'ma need a little because miles's is welded already and this is virgin. after all I'm just going to see it.
I was throwing it out there for paul that if he wanted to spend $700 or swap miles's for the one that's still at teh yard with some parts changing he could.
the one from tonight is another one I aquired differently. it is sitting until i need to move it for money. the chebby 60 would also be a store of value like this one is. I did work for it so I'm okay on money on it.
The one I picked up Tuesday night was a purchase from teh yard, and I'm putting it under the sheep.
all 3 are dually fronts. you have to swap hubs or have someone lathe off the hubs to make them straight wheel. you can also run hummer wheels with no recentering and have a $45 double beadlock total cost.
they are all 3 kingpin. the one at the yard for $700 might have sold today, don't know. if you still want me to call on it for $7, I will.
Thats aight, I really just want a HP 60 Housing, so I can build it up the way I want. 700 for a HP is pretty cheap though.
I have been wanting to put one in my HD for a while now. IFS sucks
fuggin a right it does. how many miles are you getting out of pitman, and idler arms? i'm good for maybe 7k. re-damn-diculous!
man I have 53k on mine and still have the same pitman arm and idler arm. I installed the Cognito braces and it made a huge difference. Most of my miles have had 305;s or bigger tires also. One thing IFS doesn't like is boosted 4wd launches, broke a tierod at the dragstrip and hit the guardrail.
I gotta add this one to my "Kelly's Classics"! :flipoff1:
I thought about a Ball Joint 60 but I would like to add Crane knuckles and high steer with Ram assist. Pretty much build it like I was gonna install it in a buggy, but my truck.
