Grid Heaters
My diesel engine doesn't have glowplugs? I thought all diesels had glow plugs?
How the heck does it spark the fuel then?
Lesson 101 on CTD Diesel Mechanics coming up.
:corn: :beer: :corn: :beer: :corn: :beer:
Diesel engines don't spark anything, they are spotaneous combustion realized. :D The glow plugs and heater grids are there to heat the incoming fuel/air charge so that it will be able to ignite when compressed, cold charge = no bang.
So what you're saying is, my CTD has heater grids, instead of glow plugs? And they work based on compression, to ignite the fuel. Are the heater grids 'hot' all the time, or only when the piston is TDC on the ignition cycle?
Read, absorb, learn. :corn:
Compressing any gas raises its temperature, the method by which fuel is ignited in diesel engines. Air is drawn into the cylinders and is compressed by the pistons at compression ratios as high as 25:1, much higher than used for spark-ignite engines. Near the end of the compression stroke, diesel fuel is injected into the combustion chamber through an injector (or atomizer). The fuel ignites from contact with the air that, due to compression, has been heated to a temperature of about 700
The heater grids are only on during initial start-up or when the intake air temps are "low" enough. If you ever start up your truck when its cold out, and your sitting in it, you'll see all the interior lights dim, that's heater grids kicking on:masturbanana[1]:
first gens are a lot worse since they only have one battery to pull from. You can watch my volt gauge and it won't budge with the grid heaters. But it'll drop quite a bit on a first gen.
I told my brother to find the spark plugs on a cummins one time.. Man did that take a while..
LOL. Did you see the battery Karl (Not KarlVP) put in the truck? That thing is HUGE!
Anyway, do the Grid heaters ever burn out?
That's what I was expecting when went from a 1st to 3rd gen, but the new truck acts very similar at cold startups. Lights dim etc.
