Grinding Noises
micahturner
Member
When ever I'm starting off in 1st gear I hear the grinding noise. After my truck gets going and I'm still in 1st the noise stops. All other gears after trouble free. My buddy and I just changed out the carrier bearing so I'm suspecting that that is where the problem lies but there is on play in the driveline and I can find no obvious cause. If anyone can help I'd appreciate it.
Late 70's early 80's with a 5 speed? You lost the bearings on 1st and 5th. They used the 4 speed case and added a gear in those years. They made somethings smaller to allow the extra gear. That problem came up about 3 years after the design.
I should have included that my truck is a 94 Toyota Pickup. I don't feel the grind in the shifter or clutch.
