Partly because the H2's are a factory(cheap) 17" wheel. All the good tires come in 17".
does trailready do beadlocks for them?
:screwdog:
Probably but it'll cost you
Yep.
On Pirate you can find do-it-yourself beadlock kits for H2 rims...but you can also find a lot of failures with that kit as well...
Aren't h-2's alumanum?
Been running my setup 3 yrs now.. only lost 2 inner bead in that time, both times below 6psi. Usually run 8ish.
MRW over the counter kit..
Edit: They have a 5.5" BS... on full width HP60 im 82" outside tires.
