Nuzzy
So, my dad went and looked at a truck today. '85 Chevy 1 ton Dualie. He happened to check the original build sheet and found it said it was built a Single rear and asked the guy what was up. The guy said that the previous owner had converted it from SRW to DRW with a "very solid" stainless adapter that bolts to the original wheel mounting surface studs and then has it's own extended studs to accomadate the duals. Then he got the dual fenders and bolted em on. Apparently, dad says it "looks" stock dualie width with the tires fitting fine within the wheel wells.
My question is, is this anything to be concerned about?
Would it cause stresses like wheel spacers and be considered bad? Or should there be nothing to worry about? Would this make it wider than a factory original dualie axle?
I'm supposed to report back to dad with my findings...
