HageredYota85
YOTA POWER!
- Joined
- Oct 31, 2013
- Messages
- 131
Some quick info im working on an early 22R swapped into an 88 truggy with weber carb and mechanical fuel pump. It gets fuel and air perfectly. I cannot get the distributor to fire all 4. We have tried a brand new distributor with vacuum advance and 2 others that we know are working for certain. The issue is the same with all 3 distributors. We reset the engine to top dead center on the intake stroke as well as exhaust stroke (we tried both ways just to be sure we werent 180 degrees out of time). The timing light works on the coil cable, but it is intermittent on the spark plug cables. It flashed just enough on spark plug cable #1 for us to set the engine at 8 degrees of timing. We have replaced 3 ground cables. We voltage and ohm tested ALL ignition components per internet and fsm instructions(multiple sources). Everything checks out true to specs. We even put the new distributor, coil and ignitor in another buggy and it all works perfectly normal. Sooooo WHAT COULD BE THE PROBLEM in the 88truggy that makes the distributor not work?!?!?!
