Truck has an 88 22RE that was rebuilt several years ago. The truck sat for about 4 years before i bought it.
When i got it home, drained the gas and inspected the tank, fuel filter, fuel pump and sock, reman flow matched injectors, cap, rotor, plugs, wires.
Took it to Hawks Pride and it still stumbled and sputtered. Ran a can of seafoam with 93 and that didnt help.
Pulled the codes and got a 41 and 51 which are TPS related. Tested TPS and it was bad. Installed and set the new TPS and truck still runs rich. At partial throttle theres a surge at idle as shown in the crappy video.
Tonight i changed the temp sensor and nothing changed. Theres no codes being thrown.
Theres no vacuum leaks, the air tubes are good, intake boots are good, swapped the AFM from my other Yota and no change.
So, HELP!
Im ready to slap the pane to the motor if i cant get the EFI to work properly.
Oh yeah, all vacuum lines, emissions, OEM crap is still installed...
YouTube
So, HELP!
YouTube
