help me
hunterjes
Member
ellensburg
so i put a new alternator in my truck cause my other one wasnt charging and it worked, ran and started great but the battery light and the sensor light came on, so i took the battery out and charged it, no change. then i started checking my grounds and forgot to disconnect the battery (head up a$$ syndrome) and i sparked the ground off my alternator but i did find out it was loose. so i tightened it up. now i have no power at all except my horn, lights, and hazards. theres no power going into the fuse box except for the horn. no lights in the dash come on and it wont turn over or even click. i dont know what else to do except to start pulling stuff like the alternator, starter, and battery and getting new ones. any ideas? the truck is an 81' toyota pickup w/ the 22r.
There should be two fusable links off the battery. One is yellow and the other wire I can't remember. They are heavy gage. I replace both mine with inline blade fuses in case I do the head up the azz thing.
