Freeride
Leads
20 feet, 4 gauge welding cable, 200 amp ground clamp and electrode holder, crimped on battery lugs.
Batteries
2 Exide Orbital Marine Deep Cycle (http://www.exideworld.com/products/m...eep_cycle.html )
Circuit
DCEN. Batteries connected in series by short red jumper shown below. Approx 4†long, 2 gauge.
Rod
1/8†6013
Previous Welding Experience
6 years AC stick welding, 1 year TIG steel and aluminum, 1 year MIG.
When everything is connected, I measure 25 volts at the stinger and ground clamp. Right away I find it VERY hard to strike an arc. Much harder than with my old Lincoln AC machine. I’ve never welded DC before, so I don’t know if this is inherent with DC welding, or unique to my setup. Literally, I spend 30-60 seconds just trying to strike the first arc. Once I strike an arc, it’s VERY hard to maintain. It arcs with power, but fizzles within a second or two. I haven’t been able to keep an arc going for more than probably 3 seconds. On my big AC machine I have no trouble running a continuous arc bead for the entire length of the electrode. The welds below were all done with 1/8†6013 DCEN. I tried 6011 and found it impossible to get any kind of bead going. I also tried DCEP with both electrodes and that worked terribly. The only setup that worked at all was 6013 DCEN.
Do you guys have any comments on my setup? Does everything look right? Do I just need practice? I’m to pick up some 3/32†electrodes and see if those make any difference. Beyond that I don’t know what I could change. The welding cables never get warm like I would expect if the wire was too small or the leads were too long. Even after messing around with trying to weld for close to an hour, the batteries are just a hair below 25 volts, so I have plenty of reserve power.
I can barely get this setup to weld under perfect conditions in the garage. I need it to be user-friendly enough to be able to use it lying upside down in the snow/mud in a downpour.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Batteries
Circuit
Rod
1/8†6013
