TreeClimber
So I transplanted an 87 Suburban into a TJ. The check engine light comes on, with a Code 24; No input to the Vehicle Speed Sensor.
Looks like I forgot to wire that in during the swap, which shouldn't be too hard to add back into the harness.
My question is: Does the VSS need to be accurate? In other words, since I've got an independant Speedo head coming off the speedo input from the transfer case AND when I rebuilt the tranny, I added a speedo input for the TH400 (just in case:awesomework:, since 4x4 trannys don't have one). So, if I hook up the VSS to the TH400 and it's not feeding a speedo head, does it need to be accurate?
And if you want to type extra; what EXACTLY does the VSS do inside the ECM computer (other than turn on the check engine light)?
And I'm aware that my rig should use a buffer to change the signal from A/C to HZ signals.
It's an 87 Burb, 350 V8 TBI, K-motor. Wiring harness is fully intact.
Also... do you remember where on the Burb harness the VSS is generated? Does it come from the cruise control module or from the speedo signal at the tranny/tcase?
Thanks,
Tony
Thanks,
Tony
