Hitch extensions
poopman
Active Member
Orting Wa
Anyone make their own hitch extension? I need a 20"-24" to haul jeep. If you have examples please post. Thank you
Depending on your tongue weight. I would weld another receiver section below yours. Then use a stinger. I think super hitches are a little over priced for what they are.
When I was younger we towed a 4,000lbs boat to eastern WA and back about 25 times with a single extension my dad built with zero issues.
Like Gavin said, I'd probably just weld another receiver copy the super hitch extension.
My old crew cab had a dual slide out bumper to get past the 11' camper. Worked great, heavy but worked great.
Make sure you have the support at the truck you need. I built one for my bobbed toy (so I could haul normal length stuff).
I ran the female portion all the way to the cab so it is attached to multiple cross members (works great).
The pup trailers are a good example if you are looking for examples of extreme length extensions.
