skipnrocks
So I started shopping for a fuel pump for my buggy and realize that it is a whole can of worms to get the right fuel pump. It would seem that it requires a specific psi and flow rates to work properly.
SO here is what I have. I have a higher compression tune port injection 383 that should be in the 550 hp range.
So here is what I cant seem to find. What psi pump do I need and what flow rate will be sufficient to maintain 6000 rpm?
And last but not least what compression rating do motors hit when they require alcohol?
