Joe Dillard
Member
I decided to build my own steering box brace & while I was at it I figured I would do a step-by-step mini write up incase folks are interested.
I started things out by droping by a local metal supply shop & picked up a piece of 2 7/8" OD x 2 3/8" ID x ~.188 wall x ~1'.
I tossed it in my chop saw & cut a piece ~1.25" long which would be the startings of a clamp.
I spun that short piece around so that the inner welded seam would be sliced as I cut that piece in 1/2 to make the clamp. In this pic, you can see as I draw the saw blade down, I'll be cutting the seam/weld & eliminating the weakest area of the tube.
Here I'm almost finished cutting it in 1/2.
Next thing to do was to put these "C" pieces into a vice & slightly squeeze them together so that they fit the contour of the steering box.
Here you can see that since I squeezed the slice a bit, it fits snug along the contour of the steering box and makes for 1 side of the clamp (once I attach the tabs).
I had some flat plate laying around that I cut 4 pieces to ~1.25" x 1.25" x 3/16". I'll use these pieces and attach/weld them to the "C" pieces I cut earlier and make clamps out of the finished product.
I started drilling them with a pilot hole & finished things up with a 3/8" hole so the 3/8" grade 8 bolts/hardware will fit nicely.
More to follow in my next post.
