Hot Rodder's.. need help identifing a GM 4 speed...
  • Start date Start date
P
If its free, its P
31
Your Mom's House
It doesnt have any real ID tag or anything, it has General Motor's cast into it , patent numbers and another set of numbers but thats about it. Slip yoke, small and I really have no idea what I should be looking at or for to ID this thing.
Im pretty sure its muscle car era or hotrod because of whom we got it from but I'd like to verify what it is... :dunno:
Aluminum would probably be a Saginaw , but at cast iron case could be a Muncie. Also where is the reverse linkage at? Is it on the tailshaft or on the body housing?
Reverse is at the back.
it does have 2 shifter rods on the side of it.
Its aluminum.
snapped a pic this morning.
[attachment deleted by admin]
Muncie M-20, count the output splines and i can prolly get you close the year and gear ratios
chevy four speed transmissions
The muncie reverse lever is in the extention housing, and the cover has 7 bolts.
The Saginaw reverse shift lever is on the cover, and the cover has 7 bolts.
The Borg Warner has a 9 bolt cover.
Muncies are the hot tip, since they usually were used with high performance engines. Again on the muncie, and looking at the cover, 3rd/4th gear lever is on the left. 1st/2nd gear lever is on the right.
Further Muncie identification
3 Muncie 4 speeds were offered. The M-20 wide ratio, the M-21 close ratio, and the "Extra heavy duty close ratio" M-22, also known as the "Rock Crusher". The M-22 was generally installed behind severely powerful (high torque) big-block engines. The M-22 is distinguished from an M-21 by the angle of the gear teeth. The M-22 has "straight cut" gears. Due to this, the box tends to be noiser (whines or howls almost like a blower, which is why it's called a "rock crusher") than other boxes. The M-21 has a higher pitch angle on its gear teeth.
The close ratio gearboxs generally came with 3.73+ gear ratio'ed cars. 3.55 geared and higher (numerically lower) cars used the wide ratio gearbox.
Due to the wide combination of id's, stampings, numbers, etc... varied and even GM couldn't keep track of what was what, it's best to ID your gearbox visually, taking what is stamped on the box FWIW. The best way to ID the transmission is to count teeth.
I wish it was a rockcrusher.... laughing1 begger's cant be chooser's though ! Ill count up the teeth and we will see what we got.
I planned to be 3.73 in the ass end of this thing, so thats a nice little tid-bit. :afro:
