how do you move?
skipnrocks
Billings Montana
Those of your who have rear mount radiators and run the water through the chassis how do you move the water from the rail to the block?
Pics would be great.
And if you just T into the rail do you have to worry about bleeding the system above the flow where water pools in the tube but more or less blocks or forces the flowing fluid out the T?
i run mine through the frame rails i have exhaust tube comming from frame rails to engine and radiator, approx 6" from where the hoses would normally attach...
.. i don't filter, just make sure to clean out the frame rails before adding coolant... only problem, approx 10 gallon cooling capacity..... = $$$ when buying coolant...
can send some pictures of mine tomorrow if you want. 205-335-1562
That would be great if you wouldn't mind sending some pics! Its late so I wont send you a text in case you sleep with your phone by the bed but if you want to text them tomorrow my number is
406-670-5322
