How to get Ruby speed sensor to talk to 98 ECM
Wildman1
Cle Elum, WA
Hey all,
Well my TJ is getting closer and closer to having all the little issues fixed.
But here is my current issue I am trying to figure out. When I installed the STaK's transfer case it has a Rubicon speed sensor. Now I know JB uses them and so do a few others. How do I get this sensor to talk to my computer correctly? I have the Superlift TruSpeed installed and my speedo is within 1/4 MPH off my GPS. But my tranny is still not shifting right and I THINK it is that the computer isn't getting the right signal. But now I need to figure out why & how to fix it.
The rig will drive okay but is not down shifting out of 4th into 3rd. Then on a hill when it does downshift it is a quick into 3rd then into 2nd. So this is why I am thinking it is the signal it is getting from the speed sensor. I also tried the Dakota Digital signal modifier but could never get it to work.
Wildman
A typical now a days shop scanner should show you exactly the MPH the vehicles computer is seeing so if you think it is reading an incorect signal thats how I would confirm it, get access to a scan tool.
IM guessing that you signal modifier has little dip switchs to change the setings? I ask cause the one I bought for my toyota/cheby did).
wazz said:
Wildman
Well the Dakota Digital had dip switches & the SuperLift one is just a screw.
I'll have to try my scan tool and see what happens. Hadn't thought about checking it like that.
