shotmobile
I'm going to be running a Ford 78 HP axle. It measures just under 70 inches. Now with H1 rims I have to run a 2" spacer on each side in order to clear the steering arm and the brake bleeder screw. With that combo and 12.5 wide TSL/SX's I be at 82" wide from outside to outside of the tires. This seems really wide to me. What is everyone else sitting at that is running full widths?
The other option is to chop of the steering arm, and buy special offset highsteer arms and cut down the bleader screw. That would allow me to mount the rims directly to the hub like normal. The only draw back is that my hub(lock out) will stick out about 1/2" to 1/4" past the edge of the tire. Is that really that much to worry about? Plus this will make my scrub radius right on with 38's.
So post up your thoughts and ideas.
