Hummer bead locks
Brian H
What are people using as the run flat to make these aa bead lock? I bought some wheels that didnt come with the the run flat and need to get some.
Water Pipe. Some use the green stuff but it shatters, so they are using some kind of black pipe different material.
new subdivision? Look for a excavator and look at what they are putting in the ditch.
do a search on pirate gone over a billion times there.
Finding the 16" diameter pipe you need around here is hard. Its not a normal material from what I've found. 15" is common, and 18".
You can take 18", cut a slice out of it, and plate it together (some people have even tossed it in the oven for a quick bit to get it to take a new, smaller shape with good results).
Or you can just buy them, shipping just sucks. IIRC the best ones are the UHMW ones (the black stuff). I think it was Staun that was selling them.... I could be wrong (its something like that). I've heard mixed reviews on Dean's steel ones. I know he had issues with his first couple designers... haven't looked into them since.
I have a chunk of 18" I'm going to use... cause right now I'm too cheap to buy the ones that are just done.
________
ROLL BLUNTS
