Hydraulic Steering.......
WOW! that was really fast. I just joined and allready I am totally impressed. Thank you so much for your imput on a matter that has troubled me for a while.... Thanks again
A cooler is in the near future..... I have many new things to try I will up date all with the results. Thank you for all of your imput. It has been very helpful!
I have been runing a stock gm pump for about 5 years now. Get yourself a pump off a full size van or early astro--they are an enclosed can with a nipple for a reservoir and get the res tank off the same unit. That will cure your problem without buying psc stuff...
Sweat I will be heading to the junk yard tomorrow..... Not to sound un- educated in wheeling but what is PSC????
Its a well known brand for steering stuff--I have used PSC on a couple rigs now and we are currently using it on the one I am building now....
Also on the donor rigs--make sure they are 87 and newer
I ended up drilling out the restrictor on my Stock GM pump when I added my ram. Helped quite a bit but now I need to add a cooler. Other than it works great.
