skinny_pedal
so i put in a valve....discuss?
Bootyfab boost control. :redneck:
I smell the blown parts already.
Jonathon was the first around us to try it.. 02 I think, maybe 03. Pinched the line off with some visegrips on the dyno to try and squeeze some more out of it.. Turbo went bye bye on the next run :redneck:
Could you have found a bigger band clamp perhaps :haha: :haha: :fawkdancesmiley:
dirtymax?
yeup that was a dirtymax. For some reason the dmax and the powerchoke can't handle excessive boost all that well (for stock turbos atleast). The dodges you can pinch off the wastegate and no problem. But over a certain amount you aren't getting anywhere anyways. I ran 45 psi for a LONG time on my stocker. But anything over 34 or so really wasn't doing anything for me.
reasons like this ive been contemplating trading in the dirtymax. we'll see
i like. the other reason though jeff is i really wouldnt mind lowering my payments
ok jeff whats the #'s on your truck?
once you run the turbo out of the map, it only creates heat. add a second and fix the problem.
