I need some DXF files
Harvester of Sorrow
WA State
I am working on designing an adapter...
TH400 to Dana300
I need to make my own adapter.
Still looking for DXF files of the TH400 face and Dana300 face. Can you help?
images
images
Pretty much what I was thinking.. :haha:
The 300 is easy, 6 roughly 13/32" holes spaced 60* apart. Just gotta measure the distance across. The 400 is trickier with 5 15/32ish holes unevenly spaced but even then a simple measuring of a removed 2x tailhousing will tell the tale.
Why not make it easy and source a off the shelf 400/208 adapter and get a shaft from AA?
I am still researching if that will work for my situation...It might, but my output shaft might be a bit long. In that case I would need a spacer ring.
I don't have the 208 adapter and will be looking for one of those at the swap meet as well.
Ben no I'm not completely sure of that. I'm thinking there are 4 lower and 1 upper but its been a long time since I've seen one and searching on my phone sucks..
IIRC, I don't believe they're evenly spaced.
The dd machine 231/300 doubler I just assembled can be clocked every 1/4" at the front output due to in part the ability of the 300 clocking ring being completely rotatable. :;
HOS, call me tomorrow morning (say around 9 or so) and remind me to grab that TH400/D20 adapter I have in my container (since I'll be over there tomorrow morning, probably walking over it a 1/2 dozen times). Then you can borrow that NP231 housing for the other end. Then use one of these:
and one of these:
and your golden :D
Or just buck up and tear the tranny apart and put the proper grove in. :fawkdancesmiley:
Do you have to have the files, or can you create it on paper?
Maybe this isn't what you need, but...
Piece of paper and some pencils.
TH400 & D300.
Paper over the end.
pencil on its side and scribble away.
Old school but you'll have "sketches" of the bolt locations you need.
Mark...
I am going to try and pick up the NP208 adapter at the swapmeet that looks like the photo:
Then probably space it out with either a clocking ring or a direct bolt spacer for my output shaft length...what could go wrong?
I couldnt find a pic anywhere on the net of this particular one. I will bring it to the swapmeet with me.
