Bones
That Guy
....I'd be all over these ninjas
Technically I could swing this, it's the other 20K for the buggy and then I need a tow slut/trailer.
See why I love mah bikes so much?
http://www.pirate4x4.com/forum/showthread.php?t=622738
For those of you that have not see the article featuring our custom build axles using Spidertrax parts, here you go.
http://www.pirate4x4.com/tech/harry/...toms/index.php
Because we have had tons of interest, we are going to offer complete F&R 609 axle packages. These axles are assembled with the best of everything, absolutely nothing spared. These are exactly the same axles we have put into many different WEROCK and XRRA competition vehicles with outstanding results. You will see they are still very reasonably priced.
The package will start at $13,750.00 for both axles, and will include:
-Spidertrax .25" wall Spider 9 housings. (can be upgraded to 3/8" wall)
-Spidertrax Ultimate 60 knuckles.
-True Hi9 diff's with Detroits, your choice of ratio, 2nd load bolt on the rear, and solid spacers F&R. (can be upgraded to ARB or spool)
-4 brand new F-450 unit bearings machined to your choice of 5x5.5, 6x5.5, 8x6.5, or Super Duty metric 8 lug.
-Rear full floater setup.
-Spidertrax 14" disk brakes all around, with Willwood calipers.
-Spidertrax 4340 Ultimate 60 front axle shafts.
-CTM D60 joints.
-Spidertrax 4340 double splined rear full floater shafts.
-2 pairs of drive flanges
-Twisted Customs fabricated steering arms.
-Twisted Customs .3125"wall DOM tie-rod w/ Heims.
-These axles will be fully assembled using our alignment bar, caster and pinion angle set, and fully welded.
-You will have your choice of width and pinion offset.
-These axles will allow for about 50 degrees of turn depending on your chassis. If you are looking for 60 degrees of steering we can do that as well. Give me a call to discuss those options.
-These axles will have NO link brackets. The housings are all plate steel and very easy for you to build your own link mounts.
-Please allow about 3-4 weeks as all packages will be custom.
-We will be offering this package for about a month.
-Give me a call or email me if you have any questions or need to place an order.
Thanks,
Brian
605-923-7288
[email protected]
-CTM D60 joints.
Thanks,
Brian
605-923-7288
[email protected]
