Boonie Buster
Stuck on a Curb
What would it be...
CTM U-joints or Chromo Shafts? Why?
We have been discussing this matter amongst members of our clique lately. And I'm curious as to what the masses would choose.
For the sake of argument I would choose CTM joints over chromo shafts. IDEALLY I would take both, ,but for now i'm choosing, not that I wholey believe this is the right choice... so here goes...
I figure with the stronger of the two being u-joints. the likely hood of ruining both the shaft and u-joints are less likely. if you were to break a CTM it's warrantied. but the stock shafts aren't, so finding one would be still easy and cheap.
Now, a down side would be that your weak point is the shaft and if you broke one you run the risk of messing up internals. but I feel it's no more likely to ruin them than if the weaker of the two was the u-joint, which if the u-joint was the weaker, i feel if it broke it would more than likely take out the chromo shafts with it (correct me if i'm wrong on this because i'm not truely sure if it would mess up the ears on the shaft or not)... i'll add more as it comes to mind, but this should be enough to start what i hope is a good discussion...
