If you wanna build a BULLY MOA
crash2
-Oh no I picked a side-
Da gold bar
I have been asked a number of times where I get my stuff and what it is. I have comprised a list of 99% of what I use on my own rig.
Chassis upward of $100 but prefer my own
Standard Bully axles (by RC4WD)-pair(front/rear) for $149
http://www.rc4wdstore.com/2/product_info.php?manufacturers_id=13&products_id=755
New lightweight Bully axles
Front $129
http://www.rc4wdstore.com/2/product_info.php?manufacturers_id=13&products_id=942
Rear $119
http://www.rc4wdstore.com/2/product_info.php?manufacturers_id=13&products_id=943
Pinion gears (special designed for the Bully axles)
11 tooth $6.99
http://www.rc4wdstore.com/2/product_info.php?manufacturers_id=13&products_id=691
13tooth $6.99
http://www.rc4wdstore.com/2/product_info.php?manufacturers_id=13&products_id=515
Here is the ESC that I run and prefer it over all others- Tekin FXR $95
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPNV6
If you choose to program your own FXR via your computer $31.99 Hotwire
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXSXF3&P=K
Rod ends (large Revo)$8.95 package (need 2 packages)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXHGB7&P=K
Material for links $9.49 a box
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXS021&P=K
Here are good motors (will need 2 of them) $55 a pair. I prefer the 35t motors (t refering to turns)
http://holmeshobbies.com/product.php?productid=199&cat=17&page=1
Here is a MUST have. Punk RC Dig switch $64
http://www.punkrc.com/index.php?main_page=product_info&products_id=28
Here is the Servo I am running$119.99 (HS-7950TG 486ouz torque)
http://www.servocity.com/html/hs-7950tg_servo.html
With a servo you also need a BEC $21.99
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXSWL3&P=K
If you want to program your BEC to a certain voltage $21.99 Castle link
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGVR8&P=ML
Wire $2.00 foot (13awg) I suggest 2 feet of red and black
http://holmeshobbies.com/product.php?productid=70&cat=11&page=1
Deans plugs $3.50 a pair (4 pair)
http://holmeshobbies.com/product.php?productid=68&cat=11&page=1
Shocks $38.99 (need 2 sets)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXHSR4&P=K
Wheels Any axial offset will work decently $156 for what I have (vanquish SLW's with 3 offset hub sizes)
http://www.vanquishproducts.com/vanq...oductsslw.html
Tires $10.99 (need 2 sets) Hb white dot rovers
http://www.ckrccrawlers.com/shop/index.php?main_page=product_info&cPath=103_105_85&products_id=1323
Radio $319 (needs to be 3 pos 3 channel) Dx3r is my prefered
http://www.rcplanet.com/ProductDetails.asp?ProductCode=SPM3100&click=3
To attach a body to the chassis $3.39
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001101863&I=LXN083&P=Khttp://www.rcplanet.com/ProductDetails.asp?ProductCode=SPM3100&click=3
Good quality charger $129 (can do NiCD & NiMH, 1-6 Lipo) Hyperion EOS0606I
http://holmeshobbies.com/product.php?productid=145&cat=7&page=1
Batteries.
2 cell lipo $21.95 (hyperion vx) 1100mah
http://www.allerc.com/product_info.php?cPath=3_4_93&products_id=4534
3 cell lipo $29.95 (hyperion vx) 1100mah
http://www.allerc.com/product_info.php?cPath=3_4_93&products_id=4535
And just another question can I run rear steer at the comptition and front dig
2.2 you cannot run rear steer but front and rear dig.
1.9 you cannot run rear steer or front dig
Super class is unlimited and you can run rear steer and dig.
The link for the body posts or what ever they are is still linked to the radio :awesomework:
Thats a good list of good parts, will help me out on a few things thats for sure.
Thanks Crash!
finnaly got my list done for me did yeah :fawkdancesmiley: thanks crash you just showed me how far away i really am :haha:
Thanks Crash!
Thanks eric. The link has been fixed :awesomework:
Now time to order stuff for my sons new bully :awesomework:
Dang thats a good x-mas gift, your kids lucky he must have been a good kid all year.
I ordered new axles :redneck: His is broken and I either need to spend $$ fixing his or spend a little more and give him a new rig :redneck:
Dang thats a good deal, he beats it up and breaks it and it gets upgraded.
So does the Crashfab shop do RC parts/builds yet?
Crash what are you using to bend the links? I finaly ordered some parts and tools and I will be redoing my links when I get the parts and I dont know how I am going to bend the links at this point.
A vice? or somthing else fancy? looking at a harbor frieght tubing bender for small stuff.
Do bic pens fit on your links? is it worth it?
I am using a tubing bender--works like a champ. Since mine has 1/4" on the bender its "perfect" :awesomework:
Sweet! I think I am going to have to try the Harbor Frieght junk one and see what happens.I guess I will just buy two of them when I am there then I will still have one after the first one breaks.
The voltage output will depend on what servo you run and the specs on that servo. My servos are rated at a max of 7volts so I programmed my BEC to be at 7 volts. As for running that thru the reciever--I never run the bec output voltage thru a reciever. Some recievers cannot handle the load and can easily create glitching issues.
