I've just been wondering...
TURNEROFFROAD
Camden, Arkansas
I've always thought that an Automatic locker was a major factor in axle failures due to the shock loading
So here's my question, I want to know how many guys ran an " automatic " locker and how many ran a "spooled" style diff.
I'm going to run welded 2.5 tons but am quite interested in what the Hardline peeps have to say about their experiences concerning this on say Dana 60 and up axles
1. Welded, spooled or ARB'd
2. Automatic locker
i have front and rear steer rockwells in my jeep, front has detroit and rear is welded...to be honest i cant tell the difference...shoulda saved the money and welded the front...i dont think the detroit ever unlocks anyways....machanic from chucks trucks told me if you are gonna weld a steer axle, index the shafts so the caps on the ujoints aim the same directions for less binding...dont know if theres any truth to that or not
You detroit should unlock and unlock easily as described in the install instructions. If it doesn't it is defective.
Had steer rockwells, one welded, one Detroit, stripped the splines outta the Detroit. Bought a ouverson spool, solved problem.
2 steering rocks. pulled the detroits that came in them out and welded spiders. i have seen multiple shafts broke when one tire is in the air free spinning and the driver hits R
I saw that dude with the green scout that used to enter TTC years ago BLOW UP the entire frontend,transfer case and 4 speed trans one time :eek:
It was a V8 scout on rockwells and 44 boggers, with detroits front and rear.
He was hung on the rock pile at Crawfords doin a three tire burnout "left front was bout 2 feet in air", he was goin bout 80 MPH, three other tires gettin ROASTED....
When he CRAMMED the clutch in , then dumped it in reverse with the left front tire still goin 80 MPH forward :eek:
that sumbitch made a ****ed up CLANG BANG noise,and SHOOK like a dog shakin off water for bout 5 seconds....
then Crawford got it outta the rock pile with the tractor :o
That's funny right there... :woot:
