Jeep ECU Q
boxboy
can I be your friend...
Monroe
Multi-Port Injection System by Mopar
1981-90 YJ Wrangler and CJ;4.2L (258 CID) inline 6 cylinder engines;Enhanced performance and efficiency;
  • 4.2L (258 CID) inline 6 cylinder engines
Many Years ago I bought the FI Kit for the Jeep well I think the computer is acting up.... When it gets to warm the jeep dies... once the ECU cools down runs like a champ.
I would like to find a used ECU now according to the propaganda "Mechanical components are based from production 1995 Jeep parts; therefore replacement parts are readily available."
What ECU's do I look for? any Jeep from 1995 with a 5-speed?
Also would this type of issue show up on a scan tool?
I had this same problem with mine a few years ago. It turned out to be a cam switch. I'd have it scanned.
I have a crank position sensor, it looks for the holes on the harmonic balancer.
If your interested I have an ECU from a 1990 YJ 4.2 (258) and I think I have the ignition box too. Both for $60 shipped.
a stock 1990 ECU will not work with the FI kit I installed which is based off of a 1995 Jeep...
Scott, I'd have to dig it out, but I have an ECU somewhere from a '91 HO cherokee, 5-speed, which should be the same as a '95 at least in my understanding (OBDII didn't start until '96).
If you want to try it, it's yours, but I'm not sure when I'll be that way again.
I just ordered an ECU $250 from 4wdh and the bought a Mopar crank sensor they this isn't the issue I will have some trail repair kit.
the ECU will take 7 to 10 days so this weekend I am going to put the ECU in a cooler of ice and see what happens... If it is the ECU then this will tell me.
