This is a very nice buggy that was finished by the jimmys team august 2013. It is a really nice ride that works great as any jimmys buggy does.
CHASSIS:
*Jimmy's 4x4 podium series 48" chassis
orange powder coat
*Custom jimmys front and rear bumpers
*Full umhw skids including oil pan
*Jimmy's interior powder coated texture black with recessed floor pans
*auto meter gauges
*Jimmys jeep tj front clip
* passenger grab handle
* hd steps
ENGINE
*gm 5.3L ls
*reversed intake with cable throttle body
*kevko trap door oil pan
*pace setter headers with header wrap
* moroso race bullet mufflers
TRANSMISSION
*Th350
*New TCI MANUAL valve body
*hd sprag and drum assembly
*new b&m 2000-2200 holeshot converter
*fresh amsoil trans fluid
*derail trans cooler with fan
*Art Carr gated shifter
TRANSFER CASE
* new atlas two speed
*3.8 gear ratio
*aluminum shifter knobs
AXLES
* spidertrax 9 inch axles front and rear with 3"axle tubes with 3/8 wall
* 300m axle shafts
*ouverson 300m axle joints
* mega hi-9 front 3rd
* new east coast gear supply rear 3rd
*spidertrax unit bearings
*spools front and rear
*spidertrax 14" pro series rotors/hats
*spidertrax 4 piston calipers
*Jimmys drive flanges and caps
SUSPENSION
* Jimmy's 4 link geometry front and rear
*braced link mounts
*2.5 inch aluminum lower links
* 1.75 inch upper links
*1.25 inch lower heims
*7/8 inch upper heims
*radflo 14" coilovers with PAC springs
*fox air bumps
BRAKES
* wilwood 14" rotors and hats
* wilwood 4 piston calipers
*wilwood dual master cylinder wither wilwood pedal
STEERING
*psc 10" double ended ram
*psc race orbital
* psc reservoir
*psc trophy pump
*log cooler
TIRES AND WHEELS
*39" bfg red label tires (no patches, no plugs)
*kmc enduro beadlocks
MISC
*new drive shafts
* new twisted stitch seats
* crow harnesses
*fire extinguisher
* line lock for rear brakes
*led rock lights
* led head lights
* warn rc 9000 winch with synthetic line
*optima battery
*atl fuel tank
* master kill switch
*Jimmys cooler rack
* 109" wheel base
*19" belly
*81" outside of the tires
This is a very nice buggy that works well and has had the bugs all worked out. We have had this buggy on some of the tougher trails of the Midwest and it has performed very well for us.
$45,000 price drop $39,500
Located near springfield mo
Please contact me at (417)844-4240
CHASSIS:
orange powder coat
*auto meter gauges
* hd steps
ENGINE
*gm 5.3L ls
TRANSMISSION
*Th350
TRANSFER CASE
*3.8 gear ratio
AXLES
* 300m axle shafts
SUSPENSION
*braced link mounts
*fox air bumps
BRAKES
STEERING
*psc race orbital
* psc reservoir
*psc trophy pump
*log cooler
TIRES AND WHEELS
MISC
*new drive shafts
* crow harnesses
*fire extinguisher
*led rock lights
* led head lights
*optima battery
*atl fuel tank
*Jimmys cooler rack
* 109" wheel base
*19" belly
