Got alot done today, and it is sitting on all 4 tires. The wheel base is 118.5 inches, belly height is 20 inches, and 79 inches to the highest point on the hard top. I have 5.5 inches of up travel in the front and will have about the same in the rear. A big thanks to redbarron, ying yang, duece daddy, kbwjeep, and Jonathan ( can't remeber your user name) for the help today. We have track bars, tie rod, drag link, and various things. Would have got the tie rod and drag link, but ruff stuff sent the wrong weld in bungs.
Spyntec Kit and high steer arm. The black thing is a hub condom, don't want it to catch a disease.
Moved the wiper resevoir to put the coilover mount
Rear ORI mount, these will be tied together with tubing
Made a fish plate and then welded a bung to it to mount the shock hoop
Lower Ori mount
ORI is mounted
Upper coilover mount and the gussets, the upper coilover mounts will be tied together with tubing
The axle are not centered, the front needs to go to the driver, and the rear needs to go the passenger
Looks taller than it really is
