I
InDaShop
Guest
I know you're looking, and $15k isn't too bad for a driver.
http://www.pirate4x4.com/forum/showthread.php?t=650310
Motor: Rebuilt Chevy small block 4 bolt main 350 with heads, intake and harness/ computer from a 98 Chevy truck. The harness was reworked by Cambell Enterprise. New Comp cam with lifters, springs, rods, and seats. Block hugger headers, with custom Magnaflow exhaust. The motor only has my be 10 hours on it. Serpentine kit from Summit Racing.
Tranny: TH 350 just rebuilt with new performance (Street/Strip) built. Art Carr manual reverse pattern valve body, with Art Carr gate sifter. 2400 stall torque converter with a B&M cooler/w fan.
T-Case: StAK 2 speed with twin sticks, 32 spline outputs, and 5.44 to 1 low. 1350 yokes throughout.
Front End: 78 Ford HP Dana 60, kingpin, new brakes, new bearings, new seals, PSC high steer arms, welded with 4.10s
Rear End: 80 Corporate 14 bolt, with new disk brakes, seals, and bearings. Welded with 4.10s. Blue torch truss
Wheels/ Tires: 42x17 Irok's on 17x9 beadlocks with aluminum rings.
Suspension: Fox Air shocks in all four corners, 14's in front, 16's in the rear. Double triangulated four links front and rear with 3/4 in Hiem joints.
Steering: PSC double ended ram with PSC orbital.
Seats: PRP suspension seats with 5 point harnesses.
Fuel cell: 10 gallon Summit racing aluminum cell.
Misc: Auto meter gages, rear radiator, UHMP skid plates,
108" WB
108" WB
