S10slayer
ive seen that set up on a couple of jeeps, thinking about maybe on the ranger here, any suggestions?
crash said:The only down side to this setup is the fact that its impossible to have equal flex using a stockish(sp) coil. But it will work fine...
heepofajeep said:Why is that? Coil spring rate too stiff? I guess it depends on the vehicle. I know the Toyota we did this too is definitely stiffer in the rear because of the lack of weight compared to what the coil normally sees...
Either way, coils are fairly cheap to buy with custom spring rates...
Yup, makes sense.crash said:It depends but my point was running leafs on one end its hard to get equal flex from a "stock" spring. Now you could go thru national spring and get the correct spring rate then you could get equal flex..
Little Red Zuk said:WTO-BA did ok with Waggie leafs up front and coilovers in the rear. Not much of a body to get in the way though.
crash said:But your talking about a setup that can easily be adjusted.
And how much will you guys pay for me to paint it pink here soon
S10slayer said:haha paint chris's dana 44 thats out front in ur driveway pink for him he'll love it
crash said:you must be getting old--you picked that up many months ago (back when you still had your bed)
