hwcurtice
Say, When you put LED tail lights on your rigs, either trail or road, what do you have to do 'special' to them to make them work correctly?
The true question is, when you use your turn signals, if they blink faster than normal, how do you fix this? I know that when regular bulbs blink faster, like when you have a trailer hooked up, it means you need a different blinker fuse to slow it down. Is this the same with changing out regular for LED?
