bigiron
Stuck in the Swamp
Anyone know where to buy a kit local? I need to get setup for night patrol:awesomework:
Just order the kit from Roundeyes.com Best setup on the market.:awesomework:
I was thinking LED's for the life of them....But I will probably go the route you described as 30.00 per light is a little high.Why LED's?
Go down to NAPA and pick up some 35 -55w tractor work lights or the flush rubber mounted sealed units.
They are relatively inexpensive, east to mount, and available just about anywhere when you need a replacement.
I've got a set of Vision X Tantrum's from shaffer's. I havn't got them in but they look to be good quality.
Here's the post.
http://pirate4x4.com/forum/showthread.php?t=691270
Man I thought Vision X was spendy..
I wish they would give the specs of what LED's they are using. I think it would be much cheaper just to build your own. Rub down to RadioShack and pick up some suprbright LED's. But none of the manufacturers of LED rock lights give the specs of the actual LED light.
That's a good price. That includes everything in the pic??
Here's the post.
