Totalled
That Ford Guy
Are there any differences between the two for heat exchange properties? I'm wondering if running low tox at 50/50 in my bronco might be one of the many contributing factors to it's overheating ills.
http://www.snort4x4.com/forum/showthread.php?t=39587&page=3&pp=15
About page 3 answers your question.
One of the problems I have seen at our shop occasionally is the water pump. If your PH level is too high it will eat away the prop's in the water pump and wont flow. We have even seen where the prop is completely broke free of the pulley. No leakage from outside the engine but no flow of the coolant, and then it overheats.
If your going to switch out coolant types make sure you have all of the old stuff removed. Dexcool will not mix with green coolant, it gel's up.
Just some info for you...
