Sold/Expired LS engine harness, intake manifold engine parts injectors, cam, Aluminum 5.3
alternator-guy
Whole bunch of LS parts from various projects in the shop need to go:
Complete (long block only) Aluminum block LM4 5.3L - 70 lbs lighter than an iron block 5.3L. 63,000 original miles on it, super clean inside, runs perfect but has a slight knock to it from oil starvation on hills. I would recommend rolling in new rod bearings and polishing the crank while it's out, but I wheeled it that way for a whole summer with no problems. Would be happy to take it apart and let you inspect it if you want. Comes with intake, rails, and injectors - $500
Complete good condition LQ9 6.0L heads - $250
Complete 2005 Escalade 6.0 LQ9 Engine wiring harness. (computer is sold) $100
Truck intake manifold with injectors (throttle body is sold) $40
Truck LS oil pan - $40
Located in Knoxville TN, can ship if necessary on your dime
Do you have a number to get a hold of you I need the throttle body
