tonybolton
Bypass Crawler
Any good? Any experience?
kboring said:
Thanks!Batmobile Will said:They good been running one on bat buggy for 2 years no problems
joho75287 said:I cant remember the spline count off hand. Mine should be here today and I will post up when I get it.
On my YJ - I used the proper spline count to the orbitol on one side of the steering joint then unsplined on the other side, and cut down the OEM shaft and welded it into the steering joint. That way I kept my OEM column and wheel.
I bought the steering joint from a local Smileys racing at about $20 cheaper than PSC IIRC.
Hope this helps.
joho75287 said:I "thought it was a stock rag joint...but may have been mistaken...
I would do what I listed above...find a joint with the right spline counts and rock and roll.BTW - the joint I had was shot - or I would send it to you... It wouldnt be worth putting on your rig.
