Master cylinders
crash2
-Oh no I picked a side-
Da gold bar
Who all is running there master cylinder on there buggy with no brake booster with good brake performance? I am needing one thats roughly 7" long without a ton of work to make it fit....
I have been searchin all the forums and have come up empty handed....guess I will have to just post up.
Jobless said:
I'm stickin dual 1" Willwood MC's on the heep this winter...I sure hope they work :redneck:
Is that the style that travis had on his buggy? That what I was origionally thinking since they work well for tight spot aplication...
yup Ive been running the willwood dual masters for almost two years and love em:D
Jobless said:
Which calipers you running and whats the weight of your rig?
stock toyota and my rig all loaded up with a high lift and a bunch of tools is just under 3000lbs:clappy:
Ok I found a toy master that has 1 1/16" bore but I am trying to dig up the length of it.....
Truck - '89 - '94 4WD 22RE/3VZE with abs
what about corvette master cylinder? thats what im running on the jeep, manually, 4wheel disc works like a champ! dunno how long it is tho...
How long is it spenser? I only have 7" to work with....
blackcj7 said:
1" to long so that aint gonna work.
If I can't find something then we will go with the wilwood. But I can also french it into the firewall depending on how far the res tanks are on the master from the mounting surface...
Disc or drum rear brakes? Isn't stock solid axle toyota 13/16" bore? Why don't you try the stock Samurai master w/o the booster, its 7/8" bore, if it won't lock the brakes, step up to a 1" or 1 1/16". With manual brakes you don't want to go any larger bore than necessary or pedal effort will increase. Try to lengthen the pedal ratio if you can, that will help keep effort down, but increase pedal travel.
