Nuzzy
Need to start addressing the brakes on my jeep. Will be 60/14 disc/drum to start but will shortly change to rear disc as well. After much research on Pirate, I'm thinking my best option is a '69 Vette power brakes MC for bolt up ease. Plus it was designed for 4 wheel disc. Everyone seemed to be saying it should cost $30. So I stop by Napa today to check prices/availablity out...
So here's my questions:
A) My stock CJ vacuum booster needs to be replaced cause it leaks. Should I just replace it assuming it's sufficient or should I take the opportunity to upgrade to a newer style Hydrobooster? Or would that be more work than it's worth? Napa quoted $104 for a replacement vacuum booster.
B) If I stick with the vacuum booster, the 69 vette mc should bolt right up. If I went with a newer hydrobooster, I would prob then just go to a Grand Marque (i think that's what it was) mc. Now here's the thing... Napa quoted $75 for the vette mc which seemed really high based on the research I did...
Anyone have thoughts...??
