valiant
Member
Well, I figure I should start a build page since I am getting this thing going now, Hopefully it will be done before the June 9th newbie run thing so maybe I can go out with some other people a learn the basics.
This is what I started with:
I had to take the bed off to replace the fuel pump and at the same time, I replace the old mazda carb with a weber 34/34. It has 31" Wild Country Radial RVT's on it. It also has a 3" body lift. I started to paint it military green with rustoleum spray paint.
Plan is to put it through its paces a few times and then solid axle it and swap the motor for something better.
here are some pictures:
I finally got it running today, so I decided to get some poser flex pictures. the weber 34/34 and fuel pump is on and it needs to be tuned a little, but still runs good, got a few more things to do to it, finish the military green paintjob, put on the grill guard, put the body lift back on the bed.
Thanks for looking,
Mike
Thanks for looking,
Mike
