Mine Again 98 TJ build
frankybeans
Deep up in you
Well the boy's going of to college (WSU) and he's bought himself a Prius for commutes. That means the 98 TJ he's been driving around home is mine again !!!
I've ordered an axle from Currie and i expect it here by Fri. at the latest.
Until then I'm preping the rig to install a Rubicon Express kit
Look Ma' no wheels !!!
cutting and grinding.
Tomorrow I've got My Kilby air to install.
All for now.
Went to work on my transfer case mount. I wanted it clocked all the way up and it looks sweeeet !
Bolts bolts bolts.
Belly plate with counter sunk hardware.
Kilby air
Installed and works great !!!
My rear axle showed up today pics to come.
Long day. but i got some things done on the axle .
Not much to update here. I got the truss for the Rock Jock. Decided to put it on and see how its going to work. Also installing the ARB, and gears this afternoon (and probably threw the weekend :haha: ) Hunted, and hunted for my set-up bearings that are die grinded out to slide on and off the carrier. Finally found them. So now its time to begin
And those coil mounts are just resting on the tube. I just had them on there checking something. Not even close to being in place.
Finished setting-up the gears: 4.88's ARB's in both 60's
Started going through the million boxes of parts from Rubicon Express
Billy 7100's
Also pictured is the Rubicon Express Tri-Link, Builder ball .
Axles go in tomorrow:awesomework:
