Motor Issue Possibly Solved
caglezxj
Athens, AL
Possibly is the answer. I am on 2nd and don't have much time to put in the jeep right now. I was out looking things over and remembered that the last thing I done before the mis started was I cleaned the K&N. My Mass AirFlow sensor goes in the back of my K&N . I figured some of the extra oil from the filter might have been fawking with my computer/timing etc. So I start checking the sensor and noticed the wires going to it is burned. I am pretty sure they are shorting together by the looks of it. And that kinda explains why when the temp goes up and the air flow coming in doesn't match it is throwing my timing off causing my mis. I hope this is the problem as it will be an easy fix.
I plan to buy a new sensor and run new wiring back to the computer. What a relief it will be to have this fixed. After Shamrock I am planning on redoing my front 3 link if nothing else goes South.
Does anyone have a spare hood latch for a CJ, YJ ? Mine are chrome but I would take whatever. I will be at the Shamrock Run if you can bring it with you.
I have heard a few stories about after people oiling their K&N it fouls up the MAF. Many people "decreen" MAF to get a lil extra CFM through, but if anything gets on those 3 lil elements the maf is toast and will act up. If yours is "descreened" now I would probably leave it screened with the new one, just because of the elements that its subjected to that a normal car doesn't get. FWIW...
dooooood m a s hate oil & slick juice,customers often have problems wit m a s meters that come from detail shack with pimp juice under hood!!!! plus nekkid wires nnnnever good!! got ya covered on da hood latches , man ,i got madd piles o bungee cords ,wea strop yo **** down to roll over safe status!!!!!!!! thumb.gif see you at shamrock slam!!! thumb.gif
Shiat I got da bungies on it now, so it wanna be floppin for real shizlll...
What was Shellie doing under the hood at Mountainside with those clippers? :flipoff1:
EOR MFG said:
Thats good news That stuff can make you pull your hair out
Yes it will... I took off work tomorrow so I will be pulling it apart and fixing whatever. Are you planning on the Morris Mountain Ride?
Still up in the air may be rideless after today is still got my booyang though
