Moving axle front forward?
Grommit327
Buckley
So I've got the room between my TR/DL for my axle to shift forward about an inch. Is there any cons to just redrilling the spring perch/u-bolt plate and moving the axle forward an inch? The only other thing I can see having to change is the angle of my shock mounts so they aren't offset an inch.
Or am just being a retard and not seeing an obvious problem with this
Joe
That is what we did on FiFo's XJ.
But we did it with his rear axle, and moved it back about 2 inches. No problems so far, and he beats his Jeep like a red headed stepchild.
Paulie said:
same with whit trash. if i were to do that id plate the top of the perch so it wouldnt oval.
It's a 1/4" thick perch....you think it would oval? I am just trying to keep down on the height of the perches since I am close to having TR to leaf clearance problems
What steering setup do you have? check clearance between pitman arm and tie rod on a drivers side stuff. The shocks probobly arent a big deal. Cycle the suspension and check for binding.
when i did my sas i just redrilled the hole in my spring perch one inch back. i havent have any problems so far
