War-Jeeper
Mailbox Killing War-Ho
Needs a freaking lift pump arg
Anybody ever replaced one of these in a 97' dodge cummins?:corn:
that's not too common on a 12 valver. They're easy though as long as you got arms that can reach it :redneck:
Is yours leaking, Sam? Or is there no fuel output? If it's cuz of a leak, be sure to check the return lines above it (right below the intake); they're a bitch, but much less expensive!
Pull the starter, makes life alot easier....:awesomework:
Do pull the starter it makes the job much easier. Not to tricky to do but like LUCKY said it is a bit of a reach! While you have the starter out go ahead and replace the contacts in it. They will be shot if the starter is very old. They are fairly cheap and will save much headache in the future when they weld themselves together. My lift pump was actually not bad when I replaced it but I went ahead and left it new so I wouldn't have to worry about anytime soon. I think I paid like $140 4 years ago.
12V or 24V
Also is there any other way to test these things or do you just go off the terrible noise they start making?:eeek:
neither did I. I just took it to the shop and they checked it real quick.
top of the fuel filter housing where the fuel goes in from the lift pump.
there should be a shrader valve on the fuel rail to check pressure
I assume you have done one of these then :eeek:
