WickEdKewl
Gadwd dammitt, that fukin' Dodge!!!!
So, I thought I'd run this by you folks -
The setting: 92 1 ton (last year of the first gen CTD) auto tranny with "110k" miles on it, but that's BS because the speedo sometimes was working, sometimes not - so there could be a few thousand more miles on it. An additional tranny cooler was put in @ 12k miles. This guy who previously had it gave me ALL receipts from everything from it's first oil change to the replaced pinion seals, to windshield fluid. I've got a 3 page list of everything it's been in for & at what milage - he's had it serviced every few thousand miles. Dude was a doctor, threw a ton of money at this thing keeping it serviced & fixing every squeak, and adding everything needed to pull his 5th wheel without taking too much of a toll on the truck.
The problem: OK... The speedo had been intermittently working & not working - oscillating back & forth while driving. It would work solid sometimes for 20 or 30 miles, then throw a **** fit & oscillate back & forth. Otherwise, the truck ran well. Then one day, while driving on the freeway in cruise control, the speeo absolutely stopped working AT THE SAME TIME as the cruise control stopped working. This just so happened to take place as I was about to exit the freeway, so I'm thinking "hmmm"... well, since I was on side streets for a bit, there seemed to be nothing else wrong. Shifting through gears without problems, yadda yadda yadda - except for no speedo, of course. The bigger problem was when I went to go home & get back onto the freeway - it shifts throught the gears until I get to assumably 55 or 60 or so (no speedo again), and it WILL NOT shift into that final gear. I let it get to about 2500 RPM & no shifting & nothing much more. Of course, I know that with this truck it should be shifting by 2k RPM. It ain't. So, I get off of the freeway & take side streets forever to get home. I checked all of the other gears on the auto (shifted from a stop 1st, then up to 2nd, then into drive) to see if there was something amiss... nope, just won't go into that last gear.
[foamy voice on] What say you, oh wise ones? [foamy voice off]
