hlb3
Zombie Hunter
So I am finally close on having all the parts to start assembling my wife's crawler. I am pretty much building a 2nd crawler from all my old used parts. She likes playing with my crawler, but she tends to break things, so I am building this one for her to abuse. It is mostly going to be a basher for her to mess around with while I am crawling, but hopefully I will get her to a few comps to run in novice.
So here are the specs...
-A severely mutilated and narrowed AX10 chassis
-AX10 Tranny
-Axial axles
-TCS bent links w/slick sleeves
-Traxxas 3762 shocks with rod-ends added to the caps
-Losi white springs
-Hitec 5995tg servo
-Jato shafts
-35t Warrior
-Rooster 12t ESC
-JR XR3i radio
-Rock Claws mounted on Axial beadlocks
I will also be adding the Axial slipper clutch (to help prevent some breakage) and the Axial straight shafts and plastic adapters once they come out (help keep cost down). A dig of some sorts will be coming too, since I am trying to keep this thing on a lower budget, the VF unit is out, I will probably be taking another crack at a home made one...
Here is how it looked last night:
It will be running an '07 Silverado Extended cab body, it will be left as intact as possible and will be getting a nice girlie paint job (with the help of some custom masks from George). For comp use or other general bashing, the old hacked up Betty body will be going back on it.
I ran out to RC Hobbies and picked up the axle and a few other things and it is a roller now. As soon as I get my motor and ESC back from Nick (his Goat went poof before the last comp so he is running my old setup), it will be done. I'm pretty happy with the way it is sitting, these shocks are the perfect length, I have 2.75" under the belly which is right where I was hoping it would be. I may limit the flex a little more, but I will have to wait and see how it handles. Some pics:
-AX10 Tranny
-Axial axles
-Losi white springs
-Hitec 5995tg servo
-Jato shafts
-35t Warrior
-Rooster 12t ESC
-JR XR3i radio
