Need Help with 7.3 PSD
  • Thread starter Thread starter lowbudgetjunk
  • Start date Start date
L
lowbudgetjunk
Guest
No fuel at fuel bowl....I checked all my fuses..no codes showing either. Except for dual alternator and that has always confused me. I am about to crack the line after the fuel pump and see if any is pulling. Truck is 00 and has a full tank of fuel. Sitting on the side of the road.... Help if you can
Eric Hagan......I mean Kel Lawrence
Are you getting a wait to start light when you turn the key forward? If you want to you can call me, hate to hear you stuck out on this weather! 503-435-9599
X2 You should hear the pump prime when the key is turn on.
inside the tank there are two prefilters had to drop my tank and clean mine after a bad tank of fuel
Third pump in 2k miles.....tank is clean, lines are clean, filter is clean.... Fuel pump is bad....has anyone else had issues this bad with fuel pumps?
Kel Lawrence
The sad part is the pump sounded/vibrated like normal. I just don't get it. I use good fuel and still it ate another fuel pump
Kel Lawrence
I appreciate the help and checked back to see if anyone had any ideas. Its sad how fast I got it done after getting my other truck and parts....a little under an hour with 20 minutes drive time. I guess I am just so confused as to what is making this happen. I also don't ever believe it is the pump, again. Once it started back up, after the new pump was on, I got 0231 secondary fuel.
Kel Lawrence
lowbudgetjunk said:
Thanks Steve.....still trying to wrap my head around what's wrong
. They circled the problem, it's in the middle of the grill! :woot: just giving ya hell man
Chad my bad I still have not sent the programmer back yet. :( boss man has been out of town so my work load has doubled and then some. Will get it out next week. Sorry
Where are you getting your fuel pumps from? The voltage issue could have something to do with killing them if there is a short somewhere causing a spike or loss to the pump but I doubt it.
0 Words
