jwilson645
I can fix a lot of stuff but all the calculations needed to get the right combination in my engine build is making my head explode. This is my first go at this alone. I am building an old school 350 for my 77 Silverado and here is what I have so far.
4 bolt 350 block
bored .040
crank journals are at .010 under
Standard deck height
I will be using Vortec heads and a 4L60E behind the engine. The truck is a 77 Silverado long bed. Not sure of the rear gear ratio off hand.
Goals:
9.0-9.5 CR
Run on easily available pump gas
Drive/Haul/Tow
Good low to mid range torque
Some Parts I'm looking at:
Edelbrock 2116 Vortec Intake- http://www.summitracing.com/parts/edl-2116
Lunati VoodDoo Cam: http://www.summitracing.com/parts/lun-10120701lk/overview/make/chevrolet
My main issue is deciding which pistons I need to use to get the right Quench, Squish and Compression Ratio with the Vortecs. I'd like to learn as I go so if you could give me some knowledge on why I should go with your recommendation, that'd be great.
Any help is greatly appreciated.
4 bolt 350 block
bored .040
Goals:
9.0-9.5 CR
Drive/Haul/Tow
