new and needing help
tombo83
Member
flaherty KY
Im new to crawling and want to build my own rig from the ground up. The thing i need help on is the frame and misc stuff, does anyone know where i can go or send pics or plans, any help would be awsome and thanks
Best option (in my opinion) for designing and building a simple cage to a fuul tube chassis.....You'll likely save enough in tube to pay for it. :****:
http://www.bend-tech.com/bt_pro.htm
You can plan the whole thing out before ever bending a tube. :dblthumb:
If I understand your question correctly. You are wanting to buy a bare chassis and build from there?? If this is true then below are a few companies that will get you well on your way.
EOR 3-2-1 chassis. You can order it welded or not.
http://www.essentiallyoffroad.com/
W.O.D. Sells several revolution chassis choices
http://www.wideopendesign.com/
Both of these are in mid tennessee. And there are many other companies as well as individuals that will build mild to wild.
Re: new and needing help
How close to Lawrenceburg ky are ya. I'm building one now you can stop by and see the process if you wanted.
Azrockcrawlers.com has some really good plans.
But I would say the best way is lay everything out and bend around it.
