No compression
85buggy
Is there room to pass ?
Ellijay Georgia
To make a long story short my Toyota buggy has 2 cylinders at 150 lbs.
1 at 30. 1 at 50. Oil in the radiator. Making lots of engine noise. After a friend
drove it. Without me knowing it. Which is the long part of the story. ? Is blown
head gasket ? Hopefully. Prolly going to do timing chain also while its down. Any
Other recommendations while we have it tore apart. Thx
Head gasket, new head bolts, chain, sprockets, guides, run some Tide cloths washing powder through cooling system to clean out the oil, have the head checked out by the machine shop, new valve seals and guides,....or toss in a 2.7 and be done with it.
Smartest thing I seen on HL today. :****:
I looked into it one time. You will have to get a msd stand alone ignition and find a way to put a carb intake on it. If you don't have room for a pcm you need a bigger buggy. :****:
I think Krackem's rig has a Fuel injected motor on propane. If I recall it still has the throttle plate on it. The mix is mounted to an adapter between butterfly valve and the air cleaner. It does not have a carb intake on it. But I could be wrong.
Re: Re: Re: No compression
Running a 22re on Propane is easy, just swap the distributor to a 22r unit and plumb the mixer into the intake tube before the throttle body.
2/3rz Tacoma motor is different, doesn't have a distributor so you gotta run a stand alone ignition setup to fire the coil packs.
No need for a carbed intake tho, just plumb the mixer in
The early, 96 and 97, 2.4 has a distributor. I don't see why propane wouldn't work on them. Maybe some tweaking on the ecm tune?
Re: Re: Re: Re: Re: No compression
Yep the buggy I bought has a 22re on full propane. The propane goes in just past the air filter, right before the throttle. Engine runs pretty good even though the PO didn't hook up all the vacuum connections right. Thats my next fix
Sent from S3
ibrokeit said:
Why would ya want to run a fuel injected motor on pane?
Why would you not want to do that? Simplicity, no fuel pump, no sensors, almost no wiring, safer propane, propane doesn't go bad like gas when it sits, etc.
Ok so here's the short of it. To convert a 22re to propane you need to change the dizzy to a 22r. Change the ignighter to a 22r or Chevrolet. The reason for this is the RE dizzy does not have vacuum advance. So when you upgrade to a 2rz or 3rz there is no vacuum advance dizzy for either motor. So that is why you can't put pane on the newer motor.
Now to answer the why. Stubs put it best when he said cuz my turbo loves it.
im runnin propane with the vacuum advance caped off so its same as havin an RE dizzy... works fine an always has plus if you run an electric lock off or just not even run a lock off then vacuum doesnt have a part in it
Best **** to clean ur coolin system is CLR ( calcium lime rust ) u get it at Lowes or the depot I clean radiators and any part that has calcium build up from water its flashemifyougotem
0 Words
