Noob tech - Ford Bronco F150 vs F250
slythorne
Oly
Noob here...
Is there much difference between the two? My '79 bronco is a F150 series (5lug), would it be a big improvement to get the axle and 8lugs off of a F250? Do I need to swap the springs too? It is an easy swap? Or does it require welding?
Just wondering...
:corn:
Rear end is pretty straight forward, may have to move perches; Front End is another story...both should be HP44's, so you'd be better off leaving your housing in & swapping over the 8lug setup from the knuckles out.......
